Old July 11th, 2018, 09:03   #1
fairbanks
Default What does it mean?
When after replacing the cam, the water pump, and timing belt, I tighten the belt tensioner, lock it down perfectly centered. And in the course of hand rotation (clockwise) the belt tightens, indicator is even more to the right?
Help?!
fairbanks is offline   Reply With Quote
Old July 11th, 2018, 16:17   #2
johnboy00
Must be a slow day here. I'm not an expert but I've done mine twice with a third upcoming. As long as the indicator is still in the window, and you used the tools and followed the procedures, its should be fine. see the 5th post here, BEW engines are also PD engines and use the same timing procedure: http://forums.tdiclub.com/showthread.php?t=235129
John
2005 Passat Wagon
2004 Jetta Auto
2003 IBW
1999.9 Golf (for parts)
johnboy00 is offline   Reply With Quote
Old July 12th, 2018, 11:33   #3
MEgearhead
TDI(s): B5.5, 4L
I've done mine twice and never had that problem. Did you have the three camshaft sprocket bolts loose when you set the tension?
MEgearhead is offline   Reply With Quote
Old July 12th, 2018, 14:43   #4
dogdots
dogdots's Avatar
TDI(s): None
The tensioner indicator arm will move some when rotating the engine as compression builds in the cylinders and the force to turn the crank and cam by hand increases and decreases as compression is released.
All of the spring loaded tensioners do this. Just make sure the ear of the tensioner is in the hole properly, that the 3 cam sprocket bolts are loose and cam pinned and crank pinned when you tension it clockwise, then torque the 3 cam sprocket bolts to spec, remove cam and crank locks, and rotate by hand 2 revolutions. You will see the indicator move in the window some while you rotate.
Non VW: 2011 BMW 335D and 2011 BMW X5 35D, both white, 1999 Superduty 7.3 ZF 6 speed, 2007 BMW 328xi, 2003 Mini Cooper, 1977 MB 280SL, 1977 Chevy C10 454 bought new by wife's grandfather.
www.kansascitytdi.com
dogdots is offline   Reply With Quote
Page generated in 0.11532 seconds with 12 queries
[Output: 59.38 Kb. compressed to 52.51 Kb. by saving 6.87 Kb. (11.56%)]
