Old June 29th, 2014, 21:16   #1
whoabeats
whoabeats's Avatar
Fuel Economy: 21mpg ctd 44mpg tdi
Default intermittent no starts Culprit: IP Plug
So in the past couple months I have had an infrequent, but irritating problem with my 00 alh. After driving the car and having no symptoms I will shut down the car. A few minutes later when I try to restart it the engines turns over very quickly as it should, but the engine never fires.
Because I could tell I had plenty of starter power and since it has been warmer weather I knew I wasn't getting fuel to the injectors. Also note there was no flashing gp or cels at this time of no start. Being that the IP is mechanically driven, but electronically controlled I assumed electronics were my issue. Also the first time this happened I was stranded at a burger joint on my lunch break from work and I did not want to have to call for a ride. Only thing I could do without having tools I unplugged the IP main harness connector. Everything looked fine with the connector including the weather seal. I plugged it back in and the car fired up as if nothing happened. This has probably happened 4 or 5 times total within 3 months.
This happened again today after stopping at a yard sale and it was quite embarrassing to have to get out of my car that wouldn't start and play with this plug until my car fired up. Even worse this time was the first time I had to unplug and re install the plug multiple times for success.
Has anyone had this type of issue or any ideas of remedies that I could try?
97 dodge 2500 4x4 5 speed CTD, gauges, pump work, valair dd clutch, HD Valve Springs, studded and oringed head, bd super b special turbo, DAP 5x 0.014 SAC Sticks, Devil's Own Water/Meth Injection
2000 jetta, 5speed, egr delete, stealth race pipe koni strt's, tt bushings, 3" exhaust , 17" VW Arietta wheels
whoabeats is offline   Reply With Quote
Old June 30th, 2014, 19:01   #2
CopaMundial
Probably not what you want to hear, but I'm guessing that fiddling with that cable connector is probably unrelated.
With your EGR delete is the ASV still in place? That could be sticking closed.
Did you notice whether the glow plug light was coming on at all (ie 3 sec lamp test)? If not that would be an indication of relay 109 issue.
Any signs of air in your fuel line?
CopaMundial is offline   Reply With Quote
Old July 1st, 2014, 12:17   #3
whoabeats
whoabeats's Avatar
No signs of air in the fuel. And I'm certain there was no flash of the glow plug lamp. I will look into the ASV, because it is still equipped. Im wondering if it happens again if anyone knows if there is anywhere on the pump I can check for a voltage with the ignition on or with the starter activated? That way to see if it is the plug not supplying power to the IP or something seperate.
Old July 1st, 2014, 14:17   #4
yk2jetta
TDI(s): 2000 Jetta
Good Afternoon,
Had the same problem with my 00 this time last year. I noticed when it would not start the check engine light never came on during the start sequence, most noticeably with the key in the on position. This is an indication there is no power to the ECU. Installed spare 109 relay - problem solved.
yk2jetta is offline   Reply With Quote
Old July 1st, 2014, 20:16   #5
whoabeats
whoabeats's Avatar
Originally Posted by yk2jetta View Post
Good Afternoon,
Ok thanks I'll give that a whirl.
Intermittent Rough Starts Blitz2120 VW MKV-A5 Golf/Jettas 5 March 31st, 2013 16:39
Intermittent Hard Starts axelseaa VW B5 Passat TDIs 5 October 22nd, 2011 09:18
Intermittent stalling and non-starts on first try. Tommy the diesel rat VW MKIV-A4 TDIs (VE and PD) 14 August 15th, 2009 17:11
Rough starts-intermittent smoke gmarch VW MKIII-A3/B4 TDIs 6 October 7th, 2004 10:56
Intermittent Hard Starts Switca VW MKIV-A4 TDIs (VE and PD) 7 November 20th, 2001 18:18
Page generated in 0.16397 seconds with 11 queries
[Output: 71.29 Kb. compressed to 63.26 Kb. by saving 8.03 Kb. (11.26%)]
