kathie659
Just had. work done, needed rear bearing...oil change was one of the things they did. Left shop, returned, told them I could hear a sound like something dragging. They put it on lift, found nothing. 2 days later ( today) sound noticeable louder. I looked under front end. A plastic shield which seems to have covered bottom of engine, was disconnected and the noise was this cover hitting ground when I went over bumps. Anyway the shield is falling off. Should I just remove it? I'm told it may impact cooling? Could mechanic have removed shield to change filter?
