ymz
- Joined
- May 12, 2003
- Location
- Between Toronto & Montreal
- TDI
- 2003 Jetta TDI Wagon, 2003 Jetta TDI Wagon
Is there a generally accepted method of trying to track down a wiring issue? Both of the Left side parking / driving lights don't come on with the ignition... I checked the rear bulb and light assembly (2003 Wagon), and they're fine... I didn't have the chance to see whether the front bulb's burned out, but all the rest of the bulbs in the car work as normal.
How to go about this? Does one try to find out where under the dash / fuse panel / light switch harness that particular voltage originates? Does one tear apart the inside carpeting?
Confused... (oh, I changed the light switch... no difference...)
Yuri
Yuri
