burpod
teh stallionz!!1
- Joined
- Nov 27, 2004
- Location
- cape cod, ma
- TDI
- 82 rabbit vnt ahu, 98 jetta vnt ahu, 05 parts car, 88 scirocco.. :/
Long story short.. did tb on wife's 06 bew tdi automatic, that went fine no problem. Torsion. Value of 1.5 when warm. But Nipple broke off turbo actuator, replaced with a used on that seemed to check out ok with mity vac. Car seems strained at idle and would bog when revving it and sputter. It was barely driveable and catch some hints of boost but almost nothing.
realized vnt was sticky, so took turbo off vnt17 cleaned vanes. Now when at idle, n75 to turbo line shows 23hg, 1150 mbar boost. Could rev up to 3k+ with no sputtering. Vac system holds a steady 27. Egr is deleted so vac lines are super simple. Vwmikel tuned, no smart actuator. Car will barely get up to 15mph, no boost, kinda smoky. No turbo at all. Put in a brand new actuator, same thing. Tried a brand new OEM n75.. nothing. Forgot to out the n75 line back on the actuator at some point and the car ran great!! Thought I had it fixed.
Until I realized I forgot to connect that, put it back, and back to nothing and the strained idle. Took a quick ride with boost gauge and actuator disconnected, and drove great, no more noticeable smoke than how it used to run, boosts up to 25+ psi. Looking quickly at vaglog, boost is a bit laggy behind specified but great power.
What gives? I thought with actuator disconnected I would get no boost and car would run like crap.
Is it possible I somehow put the vnt ring back in upside down such that it would act like a naturally spooling turbo based on fueling?? I'm totally confused here. Don't really want to pull turbo off again if it would be pointless. Turbo innards looked great.
