Removing
– Remove side panel trim → General body repairs, interior; Rep. gr.70
– Remove head restraint cover → General body repairs, interior; Rep. gr.72
– Open convertible roof to half open position.
– Remove roof leading edge trim → Chapter.
– Pull off roof frame seal at front from roof frame -arrow-.
M61-0017
– Unscrew securing bolts for convertible roof cover -arrow-.
M61-0018
– Pull convertible roof cover clamping beading out to side from roof leading edge clamping channel -arrow-.
M61-0019
– Pull hooking beading out of front of roof leading edge -arrow-.
M61-0020
– Unhook cord with ball -1-.
M61-0021
– Pull off roof frame seal of C-pillar in -direction of arrow-.
M61-0024
– Pull off bead from C-pillar channel in -direction of arrow-.
M61-0025
– Pull insert beading -2- off water guide -1-, if part of original equipment.
M61-0012
– Pull out headliner -2- on roof fabric retaining bar -1- in -direction of arrow-.
– Unscrew securing bolts for convertible roof cover at each pillar / each roof bracing element.
Note:
To facilitate the installation, observe of the assignment of each bolt to each hoop / each-pillar.
M61-0008
– Use force to loosen convertible roof cover on C-pillar from outside -direction of arrow-. To do this use clips (commercial type) and protect the convertible roof cover against damage with a cloth.
M61-0134
– Drill out pop rivet on frame -arrow- and remove with the aid of a drift and hammer.
M61-0135
– Drill out pop rivet on C-pillar (inner) -arrow- and remove with the aid of a drift and hammer.
M61-0161
– Pull out tensioning cable downwards in -direction of arrow-.
M61-0136
– Remove padding section of convertible roof cover upwards in -direction of arrow-.
M61-0137
– Pull out bead -2- from channel -1- of rear window -arrow-.
M61-0026
– Unscrew three securing screws on both sides of clamping profile from rear padding belt and roof retaining bar -arrows-.
M61-0138
– Pull out clamping profile -1- of corner bracing from roof retaining bar -2- in -direction of arrow-.
M61-0139
– Separate connector -1- for heated rear window -Z1-.
– Carefully drill pop rivet -4- out of retaining clip -5-.
– Pull off securing clip -3- from ball socket -2-.
– Pull hinge -6- out of ball socket.
M61-0027
– Remove bolts -3- (10 Nm) and nuts -4- (10 Nm) from body -1-.
– Press convertible roof fabric retaining frame -2- off body -1-.
The sealing band between the convertible roof fabric retaining frame and body can lead to retaining frame bonding slightly.
M61-0009
– Screw roof fabric retaining bar with fitting bracket -V.A.G 1887- to body.
M61-0028
– Take out convertible roof cover -1- on side from roof retaining rail -2- in -direction of arrow- (assistance needed).
M61-0031
– Unscrew securing bolt on roof leading edge -arrow-.
M61-0140
– Pull out clamping bead from roof leading edge -1-, roof bracing 1 -2-, roof bracing 2 -3- in -direction of arrow-.
M61-0141
– Fold over convertible roof cover forwards in -direction of arrow-.
M61-0142
– Pull out convertible roof cover at side in -direction of arrow-.
Note:
To facilitate the installation, observe the assignment of each convertible roof cover clamping beading to each hoop and to the roof leading edge.
M61-0143
