Volkswagen TDI ALH Vacuum Diagrams (Stock & Modified)
Andyinchville1
Virginia
2003 Jetta TDI wagon, 5 sp, 226K miles
The reservoir will hold vacuum, and smooth out vacuum changes, for the N75 turbo operator. I would leave it.
Hi
In typically a bigger is better world would it be a worthwhile mod to actually increase vacuum storage capacity ? I.e. maybe 2 vac balls or a single bigger vacuum Reservoir?
Mk4tdiwagon
North Carolina
04 wagon 1.9 tdi BEW engine
After using aNUT's very helpful thread to help me re-do my vacuum lines, I decided to re-make his diagrams into more complete, readable, printable, noob-friendly forms. I used his diagrams in combination with TonyJetta's labels. They're color coded so that you don't start looking at one and accidentally look at a different one next time you take a glance. I named the thread very verbosely to hopefully have this thread come up when such a topic is googled.
Here are vacuum diagrams for a stock ALH, ALH with EGR delete, and ALH with EGR and ASV delete.
Images are thumbnails. Click for full-size.
Of course it goes without saying that although these are the "shortest" paths, these are not the only options. Please let me know if I missed something or messed something up.
Thanks my guy. But, would this be the same/similar for the bew engine?
Roallingcoalaudi
Bulgaria
Afn
Hey i have a question about installing a sport filter because i saw this tube on my 1.9 tdi afn intake with a t connector like in the diagram so do i need a special piece or if i leave it unpluged is there going to be problems with my engine
(The tube that goes to n18 n75)
FlyingFin
UK
A4 Avant AFN
Why do you want to add a sport filter...
There are several threads on how useless they are on a diesel engine...
Dlesp52
ON
2002 Jetta tdi
Thank you for this!! Last owner made a damn rats best of hoses!
NevilleMccoy
LONDON
After using aNUT's very helpful Speed Test to help me re-do my vacuum lines, I decided to re-make his diagrams into more complete, readable, printable, noob-friendly forms. I used his diagrams in combination with TonyJetta's labels. They're color coded so that you don't start looking at one and accidentally look at a different one next time you take a glance. I named the thread very verbosely to hopefully have this thread come up when such a topic is googled.
I'm pretty sure it is only used for the ASV. That would clean things up even more. I'm not totally sure about that but I think I'm gonna give it a try.
