bennyandtash
- Joined
- Mar 5, 2005
- TDI
- 87 cabrio red
I am having trouble with my diesel engine. It is a fresh rebuild, and has a ton of compression, now the starter motor will barely turn over the engine, and gets really hot (hot enough to burn my little fingertips) and starts smoking through the alignment hole in the bell-housing. The starter turns the engine slowly for about four revolutions, and then dies. The engine turns freely (although with some difficulty) by hand, so we know it is not hanging up on some sort of mechanical seizure. When I pull the glowplugs, the engine turns quite quickly. Could the starter die under load? Anyone ever seen any problems of these sort? Battery was on charger all day. Thanks in advance.
