P Pawel23 Member Joined Jan 12, 2004 TDI Jetta 2001 Silver Aug 29, 2004 #1 Hey Everyone Just one quick question for you here When replacing Coolant temperature sensor is it necessary to drain the coolant just a little??? Thanks For Your Help Pawel 2001 Jetta TDI
Grady Veteran Member Joined Feb 4, 2000 Location NW Oregon TDI '01 Jetta Aug 29, 2004 #2 That would help to reduce the "panic factor" when the coolant starts leaking out. Here is some info shared by others which may help. http://forums.tdiclub.com/showflat.php?Cat=&Board=UBB17&Number=808881&
B bjmarler Veteran Member Joined Jun 23, 2004 Location Tullahoma, TN TDI Jetta GLS, 2004, White Aug 30, 2004 #3 Is this a problem still for the 2004's???
