jimigunne
Its not burning out the controller in the dash, but it has melted/ burned up the fuse socket contacts without popping the 30 amp fuse itself. I suspect there is supposed to be a smaller fuse! Whats the proper fuse size and how much should the blower normally draw on high? I think this high current situation has been going on since before i got the car, and someone has probably put in a larger size fuse. The wire itself is handling this amount of current without melting.....just barely. I need to run blower on high.....but im really pushing it with it drawing 27 amps on high speed!
