golfere
Hey there;
Seems like my car has less throttle response after replacing the turbo with a stock oem kp39; it squeals when turbo kicks in louder than before; I will check the actuator as i did accidentally get some diesel inside of the vacuum port and this could have screwed it up; I have vcds so once i fgure out exactly how to check and how to post logs etc i will keep you guys updated
Any help on that is greatly appreciated also! Thanks in advanced
