Old March 19th, 2018, 21:54   #1
simonbee
Default Manual transmission clutch package
I was wondering what people are using for clutches when doing 5 speed manual conversions and what result they had with it.
I am gathering hardware for another conversion and wondering if the clutch package I used was an overkill. This what I used: South Bend stage 3 Daily with a LUK DMF made for 1.8T gasser. It is rated for 395 FT-Lb of torque. I also have a stage 1 malone power upgrade. The cost of this package was close to $1000. I have about 12K miles on it now with no issues. I like to find cheaper package but as reliable.
simonbee is offline   Reply With Quote
Old March 20th, 2018, 08:40   #2
PickleRick
PickleRick's Avatar
For not much more you can use the whitbread 240mm clutch kit (300 model i think) which is listed as Matt's personal favorite on his site. It doesnt require a spacer. It has stock pedal feel and will handle anything the motor can put out until you start getting into mods that require heavier duty rods and head studs.
For a budget, if i was not going to use anything other than a stock horse power tune I'd use the heaviest single mass 1.8t passat flywheel kit i could find and a clutch kit capable of holding a 250 ft/lbs of torque.
Should be able to budget one of those for sub 500 bucks..maybe sub 400 if you look for deals/sales.
That's the info I've found, but when getting into kits that handle tunes you're looking in the 700 to 800 range and up
Nobody exists on purpose. Nobody belongs anywhere. We’re all going to die. Come watch TV.
PickleRick is offline   Reply With Quote
Old March 20th, 2018, 10:05   #3
zzdiesel
I used the clutch from Franz. Single mass flywheel. Stage 2 tune. 2 years and approaching 40000 miles with no problems. I do wonder if with the delete kit if a DMF flywheel would be smoother.
zzdiesel is offline   Reply With Quote
Old March 20th, 2018, 10:24   #4
Jake Brake
Jake Brake's Avatar
Default My clutch slipped
I too went with the european smf cluch and flywheel grom Frans. It was fine until i got my stage 2 tune. It slipped everytime you gor into 4th and 5th gear and got the least bit frisky with it. I had to have Southbend reline my clutch disk with a better material. I do tow a fairly heavy load ever now and then.
Jake Brake is offline   Reply With Quote
Old March 20th, 2018, 12:54   #5
richmondvatdi
I bought a recently-converted tdi wagon from a forum owner 2 years ago. I've put 60,000 pretty easy miles on the 1.8t DMF/clutch setup. The clutch is grabbing when stsarting out from a stop and the DMF is beginning the death rattle. No more messing around for me, after reading everything I could find on this topic I just ordered this setup:
https://whitbreadperformance.com/col...=4708260118557
I really hope it's the end of my clutch issues for a while.
2005 Passat TDI Wagon, 5-speed, 230,00 miles (9/1017)
2003 Jetta GL TDI Wagon, 5-speed, 340,000 miles (9/2017)
2003 Jetta GLS Wagon, 5-speed (conversion), 250,000 miles (9/2017)
2013 CC Sport, 6-speed, 2.0 TSI, 78,000 miles (9/2017)
2004 Phaeton W12, 108,000 miles (9/2017)
richmondvatdi is offline   Reply With Quote
Old March 20th, 2018, 17:56   #6
PickleRick
PickleRick's Avatar
I don't have any personal experience with the DMF but I've heard too many failures with them on the little 1.8t to trust it with the torque (and torque pulse) from a diesel.
Old March 20th, 2018, 19:02   #7
richmondvatdi
Not sure I would generalize to all diesels. I put a Luk DMF in my ALH A4 (Malone Stage 2) at 250k. It's pushing 350k with zero issues. The 1.8T DMF may be exceeding its limits on a mildly tuned PD though.
Old March 20th, 2018, 19:05   #8
Uberhare
Uberhare's Avatar
TDI(s): Too many.
Fuel Economy: Depends on what I'm towing!
I used the stock 240mm DMF & clutch setup for 5 years without issues. (tuned)
2004 Passat W8 Variant, awaiting BHW swap
Retired: 2005 Passat BHW Variant w/01E 6 gang
Uberhare is offline   Reply With Quote
Old March 21st, 2018, 04:22   #9
PickleRick
PickleRick's Avatar
I might be a little over cautious as one of my BHW motors (possibly 2 of them) is going into my boat so after reading/hearing a few stories of them coming apart, im a little hesitant to trust one. Below a car motor is asphalt. Below a boat motor is fiberglass and then an ever changing depth of water. Tow boats USA doesn't cover a sinking. Solid mass for me please and thank you. Just think of the poor manatee. What if my boat sank and they got all my beer? Fat slow vegetarian frat boys. There would be memes.
Old March 21st, 2018, 11:11   #10
blazen71
blazen71's Avatar
Fuel Economy: 36.6mpg
I didn't do the swap on my car, but the guy who did it 6 years ago believes he used a euro dmf set-up. At 30k miles it slips in 3, 4 and 5 if I give it more than part throttle. Hope that helps.
I'm your Huckleberry
blazen71 is offline   Reply With Quote
Old March 21st, 2018, 12:40   #11
simonbee
One of the reason I used a DMF was wear and tear on the sincros. I also have a Geared BSM. I assume the 240 mm flywheel arrangement is used in the V6 gassers? This also required a different starters than the original TDI? Spacer?
Thanks for all you opinions.
Old March 22nd, 2018, 08:22   #12
50mpgtdi
Fuel Economy: 36-41MPG
The flywheel/clutch I used for my swap was a no name single mass flywheel and 6 puck solid disc for a 1.8t passat from ebay. It's holding torque is great. The only recommendation I would make is to get one that has a sprung disc. It can be a little harsh on takeoff with both the flywheel and the clutch disc being solid. But it was cheap and served my purpose at the time of the build. Under $400 for the whole set up.
50mpgtdi is offline   Reply With Quote
Old July 10th, 2018, 09:57   #13
50mpgtdi
Just to update my input in this thread.....I've learned the hard way that solid light flywheel and solid disc is not a good combination. Very hard on syncros. The aforementioned 6 puck ceramic killed off 2 transmissions so I changed to a solid organic disc and it has now KOed another transmission. I will be changing to a heavier flywheel and disc, either dual mass flywheel or sprung disc, whichever I find to be more suitable to my application with the Malone stage 2 tune I will be getting.
WTB: ALH TDI manual transmission swap package sewerzuk Private TDI Items for Sale/Wanted 12 April 13th, 2015 14:15
FS: ALH Motor/Clutch/Manual Trans - Package($2000) Kevin_McC Private TDI Items for Sale/Wanted 3 January 13th, 2014 09:21
WTB: Clutch and transmission manual '01 TDI T_D_I Private TDI Items for Sale/Wanted 0 January 15th, 2009 11:39
Manual Transmission Clutch shudder seattlemagnum TDI 101 4 August 13th, 2006 15:44
Manual Transmission Clutch shudder seattlemagnum VW MKV-A5 Golf/Jettas 5 August 7th, 2006 19:10
Page generated in 0.15983 seconds with 11 queries
[Output: 113.18 Kb. compressed to 94.88 Kb. by saving 18.30 Kb. (16.17%)]
