The4ork
Well i was planning on dropping the tdi in the mk1 but since i snapped the timing belt in the 8v, and most of the nuts/bolts i needed to remove to replace the belt were stripped (thanks previous owner!) i had to pull the motor... (just to replace the belt, to get access to all of them with easy-outs)
SO... while i had the engine swap 1/4 way done i figured, well i guess i'll just do a tdi swap while im at it, since i had just recently purchased a mk3 tdi parts car for my mk1 swap.
so here we go....
Getting the engine out, the thing i hate the most are the axles, so i tackled them first... and this was a first... BOLTS? never seen bolts holding them on before, this made it extra challenging, i couldnt use my electric impact, had to turn them all by a hand wrenceh
TDI engine out....
Mk3 engine bay...
Clutch is still good so im re-using it
Shift box install....
this was ALOT easier than i had thought. I did ZERO modifications except for one hole i had to drill, which i eyeballed and lucked out on the first try. This nut you see just FWD of the shiftbox is where i drilled, and the stud from the shiftbox came through the floor, and then the nut installed. Now its holding the shift box in place where i wanted it, and i can get to the rest from under the car....
Here you can see the shiftbox is narrower than the stock one, but i used the bolts that held up the stock one and ran them through the holes, its not ideal but it worked, and that thing is held in SNUG. could have used some washers for added durability but after feeling how stiff it was i was more than happy just leaving it like this.
My parts car had driven into a ditch and had some body damage, this was the mechanical damage it had....
had to install a 3/8" helicoil in the center bolt hole for the rear trans mount bracket
so here we go....
TDI engine out....
Mk3 engine bay...
