bigblackcaddy
I have a bit of a puzzler and I thought I'd solicit some help. The other day I was driving my 2000 TDI Golf and I noticed I suddenly had no power. Boost gauge does not move. My exhaust manifold pressure gauge also does not move. I never heard a pop, but I checked for blown intercooler coupler for my front-mount and everything seems fine. Checked for a holes/cracks/leaks in the exhaust manifold and nothing obvious (I have a cast manifold with an adapter and a GTB turbo). So I get out the VCDS cable and laptop and it won't connect to any module. I run the test and make sure the com port is correct and it sees the interface just fine. I run the auto-scan and and every module times out. I looked at the OBD2 connector and there are no pins missing or pushed out, and I have the factory radio (but I did hook up an amp with the blaupunkt ISO adapter). I've used the very same VCDS cable and laptop before, so that hasn't changed... If the ECU died why does the car still run with no CEL (albeit with no boost)? If just the N75 died, how come I can't scan anything? Arrrgh! Anyone have any ideas?
