Old July 18th, 2018, 11:06   #1
jbrill
Default Rear rattle - brake splash shield
Been driving around with an annoying rattle coming from the rear driver side wheel (05 TDI Wagon). Took the tyre off to inspect pads/rotors where I discovered what I think is the culprit... the brake splash shield is hitting the rotors...
I pushed/bent it back and noise was gone for a couple of weeks but is back again. Short of replacing the shield or simply removing it, any one else dealt with this and have a simple solution?
2005 TDI Passat Wagon, Stonehenge Grey
1983 Jetta, Diesel, Blue (RIP)
jbrill is offline   Reply With Quote
Old July 18th, 2018, 16:45   #2
QuickTD
Bend it some more. It usually gets deformed at the top when the tire jockey lets the wheel fall and hit it on the way off. You need a 1/4" of clearance all around.
QuickTD is offline   Reply With Quote
WTB VT/NH: Left Rear Brake Splash Shield xbiker423 Private TDI Items for Sale/Wanted 0 March 21st, 2015 10:13
Brake Rotor Splash Shield TDI-Newbie TDI 101 7 June 19th, 2012 07:47
Front Brake Splash Shield Help thebigarniedog VW MKIII-A3/B4 TDIs 5 March 23rd, 2011 19:42
stupid dealer lost my rear 3 splash shield bolts philip_g VW MKV-A5 Golf/Jettas 17 July 17th, 2010 00:05
A4 Rear brake rotor dust/splash shield or backing plate help y2kbird VW MKIV-A4 TDIs (VE and PD) 6 December 13th, 2009 16:21
Page generated in 0.15205 seconds with 13 queries
[Output: 52.09 Kb. compressed to 48.11 Kb. by saving 3.98 Kb. (7.64%)]
