icanreachit
Just wondering if anyone could help with a few codes that are reluctant.
17569 - Manifold Temp Sensor (G72)
P1161 - 35-10 - Open or Short to Plus - Intermittent
Pulled the plug, cleaned it, pulled the shroud on the wire up to the next junction, no issues. Cleared the code and it keeps coming back. I am reluctant to swap the sensor until I can confirm that everything else has been done. I've seen some videos on cleaning it, but not sure that this would resolve the issue.
17849 - EGR Valve (N18)
P1441 - 35-10 - Open Circuit or Short to Ground - Intermittent
I removed the N18 so... I'm thinking I just need to re-attach it to the connector? I've tuned it down with VCDS. In another thread I saw that you can (credit Keaton85)
Add a 10watt 30-40ohm resistor to the connector and completely remove the N18.
I don't have the ASV so I'm not sure how to run the vacuum lines, just plug the line to it? I'll try to replicate the model in the link but keep my vacuum reservoir.
