jjsbiggs
I have been trying to help a friend who has been having a problem with low power on his 1999.5 jetta tdi. It doesn't seem to have any power but does not throw a code or go into limb mode. In the lower gears (1-2) it will start out like it has some boost but as the rpm rises it almost feels like you are backing off on the fuel. I have Vag-Com and the MAP pressure starts out pretty close but as the rpm rises the actual drops off compared to the requested but it never goes into limp mode. I checked the turbo actuator with a hand vacuum pump and it is moving and holds vacuum. I put a vacuum gage on the control line for the actuator and you can see the vacuum change to the turbo with change in demand for boost. I thought I would try changing all the vacuum lines in case there is a leak somewhere. Is there a spot I could connect my hand vacuum pump to to verify the lines are vacuum tight.
Any other help would be very welcome. The car has about 150K on it and I replaced the head and turbo about 1 1/2 years ago as it had been overheating back then if that is any help.
