cspeter8
Hi,
I bought a 2001 Jetta TDI Sedan, and then discovered the horn does not work! Swapping the 20a fuse with another fuse tested in the windshield washer circuit proved the fuse was good. Does anyone have ideas on what the likely problem may be?
This may/may not be related: The airbag indicator is always lit on the instrument cluster.
thanks
thanks
