2001 Jetta with nonworking horn
cspeter8
Central Connecticut
2004 Passat Sedan
Hi,
I bought a 2001 Jetta TDI Sedan, and then discovered the horn does not work! Swapping the 20a fuse with another fuse tested in the windshield washer circuit proved the fuse was good. Does anyone have ideas on what the likely problem may be?
This may/may not be related: The airbag indicator is always lit on the instrument cluster.
thanks
powrmatic
london ontario
2004 jetta tdi
well this might help I had the same problem on my 04 jetta. if you follow the wire from the fuse panel over 8 or or so inches the 04 has a relay that is square there are two or three of these relays in thr same spot. try switching them around. thats what mine was?
powrmatic
london ontario
2004 jetta tdi
cspeter8
Central Connecticut
2004 Passat Sedan
Thanks for the suggestions - the relays suggestion sounds promissing. I neglected to say this is a GLS model. When locking the car, the horn(?) sounds with a very short sound - do you think this indicates that wires are connected to the horn? Also, where is the horn located - I looked around and could not find it in there.
cspeter8
Central Connecticut
2004 Passat Sedan
Thanks for that horn location. I found it no problem. The wiring going into each horn looks pretty good, although it didn't seem obvious how to remove the bumper to get a really thorough look.
Perhaps I have a bad or missing relay? Are they those cube-shaped things about 1" wide that plug in? I saw a few of them plugged into a thing with holes to plug the prongs into, up inside the dash just inside from where the fuse panel is. There seems to be space for a few more relays than what I saw there. Would it be in that area?
Is there a way to determine the exact location of the relay for the horn circuit? I don't hear any noise whatever when I push on the horn/airbag area of the steering wheel.
thanks!
FL2AK-tdi
Tampa, FL
'01 Jetta GLS Sedan
Lefty said:
Fuse listings for your car. #40. Dual tone horn (20A). Might try changing even if it looks good. I had a fuse look good before and it wasn't.
Test with ohm meter.
alphaseinor
TDI Innovator, Gone but Not Forgotten
Denton, TX
'03 Jetta TDI 780,000 miles (totaled out), 01 Audi TT 225 Quattro 230,000 Miles (runs great!), 00 Cabreetle Beetle dash, ALH & MK4 harness Swap
I like to check for voltage, if you are getting voltage to both horns, then you've got a bad horn. they tend to get water in them, and go bad.
FL2AK-tdi
Tampa, FL
'01 Jetta GLS Sedan
You should hear them when they get water them and then the water freezes; it's actually pretty comical.
FL2AK-tdi
Tampa, FL
'01 Jetta GLS Sedan
Lefty said:
I knew there had to be another way. I have had an Ohm meter for 20 some years and never can remember to use it. Let alone find it.
Pull fuse.
Connect meter leads to fuse terminals, one each, polarity irrelvant.
Take reading.
No reistance = good, high resistance or no reading = bad.
cspeter8
Central Connecticut
2004 Passat Sedan
YES! - I figured out the front bumper removal (not so hard once I looked it over) and unplugged each horn and tested for voltage ... The ignition has to be turned to where the instrument cluster lights up, then I had my wife push the horn control. I did hear the clicking of the relay, and I did see 12v on my voltmeter on each of the 2 pairs of horn leads.
I am missing both side-skirts along with the plastic cover for under the engine - perhaps this caused the horns to get wet? The guy who sold me the car is sending up 2 replacement horns, so I will find out soon if the horn is fixed for sure...
If it was water that killed the horn, then is there anything I can do to keep the water out so I don't have to keep replacing the horn? Or is it best to stock up on a few at the auto salvage yard in advance?
thanks again alphaseinor !!!
Ben1000
Greensboro, NC
2001 Baltic Green 5spd
cspeter8 said:
... If it was water that killed the horn, then is there anything I can do to keep the water out so I don't have to keep replacing the horn? ...
Keep the water out by putting on the side skirts and at least the plastic skidplate.
The sideskirts are about $15 each new, the skidplate is more but you may be able to find one that is good enough at the salvage yard.
Doing this willl pay off in cleanliness every time you work under the hood, and minimize the chance of water in horn.
Having the underside of an A4 platform naked is a scary thought, road debris does not get along well with a serpentine belt that is so close to the pavement.
Mufuart
Pasadena Ca
2000 jetta tdi 1.9
My horn was not working on my 2001 Jetta TDI. We swapped relays around and boom horn is working the relay for the horn was broken.
