grizzlydiesel
Hey all, havent been on here for a minute... 60 hour work weeks and busy weekends have kept me away from the habit
Anyway, just put my car in for service, and found my two rear tires were completely bald on the inside edge. Ive been running all my tires at 42psi, front tires were fine. Since i had no spare, and the tires were from the PO and were bo-bo brand, i replaced all five tires with new units and had an alignment done. everything seems to line up.
So the question is, does the solid rear axle on the 2000 jetta have built in camber that might cause higher tire pressure to wear only the inside edge of the tire? should i drop my rear tire pressure when im not on the highway? As it is, I plan on rotating my tires every 5000 miles, (every oil change, i run B20), tires are expensive. but wanted to pick yalls brain and see if maybe anyone else had this problem.
