Recently I topped off my oil, but I put a little too much in (level is at the max, not overfilled). When it's cool out (below 60°F), the engine tends to burn a bit of oil (blue smoke) for about a mile. It also won't do this if it's warmer out (e.g. above 70°F). The oil consumption previously was pretty normal, about a quart every 2,500 miles, but I'm not sure if that's increased. The car has 268k miles. I also recently had the ECU flashed with a Malone Stage 3 tune with dynamic idle, which could be related.
Should I be worried at all? What should I be looking into? I've read that the valve guides and guide seals could be a reasonable culprit.
