charlestdi
Problem:
Yesterday I was driving about 95 when the car stumbled a bit. I made it home but the engine was suddenly stumbling between 3k and 4k rpms. I looked at the fuel through the translusent tube and it appeared to have more air in the line than I had ever seen before. I tightened the fuel filter lines to ensure it wasn't sucking air. I have read the FAQ's and it doesn't have the same symptoms of a MAF. This morning I got up to seventy and it started to stumble again even when pulling away from a stoplight at around 2k RPMs. I disconneceted the MAF and it was still stumbling.
Background:
I have a 2003 Jetta Wagon with 76k on the odometer. I was upsoluted 50k miles ago, ventectomy, mufflerectomey,2" lift.
I changed the fuel filter,air filters,oil filter and oil 6k miles ago. I have been running b-99 for the past 2 months and have used amsoil since the car was new.
Any suggestions?????????
Background:
