lukelbd
To bleed my brake lines, I use this special bleeder bottle
from amazon, which prevents air from coming back into the system when releasing the brake pedal.
However I noticed from the myturbodiesel guide that the clutch fluid needs special considerations -- they recommend pressing the pedal all the way down once, and closing the bleeder valve each time, instead of pumping.
How could I adapt this to a solo method? Would I need a brick or something to hold the pedal down every time?
