phamine
Selling a B4 Wagon that I never got to do an ALH conversion on. Maybe someone else needs this car for that project?
Runs and drives
Parts that I've replaced during ownership
Parts - Ignition Switch (9.00)
Parts - Water Hose, Water Pump, Seal (56.00)
Parts - Water Pipe, T-Stat w/ housing, Water Hose (73.00)
Parts - Cabin Filter, Serpentine Belt (28.00)
Parts - Serpentine belt Tensioner (38.00)
Parts - Trans Fluid and Filter (56.50)
Parts - Control Arm Bushings (34.50)
Parts - Spark Plugs, Wires and Air Filter (98.00)
Parts - Window Regulator (69.24)
Parts - Front pads (39.00)
Parts - Rear pads (32.00)
Parts - Rear discs and bearings (36.00)
The Bad:
- Driver side window regulator works but runs off track
- Ripped front seats
- Paint isn't in the best shape. Notably Silver primer front and rear bumpers and rear driver side door
- Transmission beginning to slip
- A/C works but there is a pinhole in the condenser that needs to be soldered or replaced.
347.866.5203
$600
Runs and drives
The Bad:
347.866.5203
$600
