Hello have a 2002 vw TDI Been having problem with loosing prime from fuel tank. Causes a no start problem .This is model that has no fuel pump,just injection pump to draw fuel from tank. Replaced fuel filter and cleaned the fuel pick up in tank. I ended up adding a lift pump in engine compartment to liven it up .Now I need to figure a good location to get power .Trying to find a way to wire it so a safety shut off can work with pump.Thanks
