Go Back   TDIClub Forums > Classifieds/For Sale/Wanted > Private TDI Items for Sale/Wanted
Private TDI Items for Sale/Wanted VW TDI/Diesel related items for wanted and for sale by private individuals. Group Buys and commercial posts should be in the "Vendor & GroupBuy" section.
Old April 1st, 2016, 09:31   #1
GotEuroCorrado
Default Wtb: bhw / b5. 5 passat front crank seal carrier
got one in the mail.
ACS TDI SPECIFIC MAINTENANCE AND REPAIR IN HATBORO PA (267)317-8229
$600+/- ALH/BEW/BRM/BHW TIMING BELT KIT INSTALLED NEAR PHILADELPHIA !
used parts FS: http://tinyurl.com/zfdjgyh
smoking deals on TIMING BELT KITS: http://tinyurl.com/ov57jfl
GotEuroCorrado is offline   Reply With Quote
Old April 2nd, 2016, 11:06   #2
GotEuroCorrado
anyone?
Old April 2nd, 2016, 11:46   #3
97caron
TDI(s): NB
Default BHW seal carrier
These are rare. I had one a year ago. Only ~25,000 of the engines came state side.
97caron is offline   Reply With Quote
Old April 2nd, 2016, 13:17   #4
GotEuroCorrado
I would not say super rare.. I buy them regularly on the forum here fairly cheap.
Sent from my SM-N910T using Tapatalk
Old April 3rd, 2016, 01:24   #5
fryerdiesel
Fuel Economy: 46 highway
Let me check my engine tomorrow when it's light out and I'll get back to you.
'02 Jetta GLS 5-speed PD lift pump VR6 clutch and G60 flywheel
fryerdiesel is offline   Reply With Quote
Old April 3rd, 2016, 11:02   #6
CRSMP5
TDI(s): idi
why do you need to replace that often?
CRSMP5 is offline   Reply With Quote
Old April 3rd, 2016, 11:55   #7
GotEuroCorrado
i do a lot of bsm deletes. often when they unit starts to fail it blows out the seal carrier.
Old April 3rd, 2016, 12:35   #8
97caron
TDI(s): NB
Default BHW Seal carrier
If your doing BSM delete a BEW seal carrier will work.
Old April 3rd, 2016, 12:48   #9
GotEuroCorrado
it will work if i drill the block and im not looking to do that to make a bew carrier fit.
Old April 5th, 2016, 16:02   #10
GotEuroCorrado
bumpers
Old April 5th, 2016, 19:01   #11
jimbote
jimbote's Avatar
could you use a CR cbea/cjaa seal carrier ?
Old April 5th, 2016, 19:13   #12
GotEuroCorrado
no idea, i think it may be the same. i dont have etka to confirm.
Old April 5th, 2016, 19:18   #13
jimbote
jimbote's Avatar
no idea
i'm pretty sure you could, they both have the larger housing to accomodate the larger drive sprocket/gear and both have the timing tool pin hole ... i know the pan bolts are in the same spot
WTB: bhw (b5.5 passat) parts GotEuroCorrado Private TDI Items for Sale/Wanted 0 November 16th, 2015 15:14
WTB: Front crank seal carrier Bczuk Private TDI Items for Sale/Wanted 1 February 19th, 2015 10:46
WTB: Front seal carrier ALH rhg Private TDI Items for Sale/Wanted 2 November 17th, 2013 10:33
WTB: ALH front crank seal carrier CommieGIR Private TDI Items for Sale/Wanted 2 August 25th, 2013 14:55
WTB: Front oil seal carrier for ALH djamwolfe Private TDI Items for Sale/Wanted 2 March 23rd, 2011 16:47
Page generated in 0.16401 seconds with 11 queries
[Output: 111.89 Kb. compressed to 93.18 Kb. by saving 18.70 Kb. (16.71%)]
