go_tdi
my left turn signal lamp is continuously on, not blinking just on, key removed from ignition light still lit. i removed the 30A fuse to turn off lamp over night.
help
help
What steps have you taken to troubleshoot the problem?my left turn signal lamp is continuously on, not blinking just on, key removed from ignition light still lit. i removed the 30A fuse to turn off lamp over night.
help
You missed my point. The ground problem I was refering to has nothing to do with the ground the lights have so yes, they will function as normal with normal voltage. The ground issue I think he's having is something else on the car not grounding that is sending stray voltage through his turn lights. Example, a car I was working on in the shop one day would stay running when you turned the key off as long as you had your foot on the brake peddle.Take your foot off the brake and it would stall. We found out that the owner had just previously did an engine swap before this problem arose and on checking into it we found a ground strap under the radiator that wasn't reconnected during the engine swap. Without a good body to engine ground the brake lights on this car was grounding through the ignition keeping the engine running even when the key was turned off.Both front and rear lights, at full intensity? Likely not a ground problem then.
does the vehicle have an alarm fitted that blinks the lights? Certain brands have internal relays that are known to stick, causing this problem.
