Old April 3rd, 2018, 10:04   #1
nomorotors
Default Another B5 Passat Crank No Start Issue
I searched quite a while and all the TDI no start issues resembling mine either had "no glow plug light" or "flashing glow plug light".
Here we go:
05 Passat TDI
Ran just fine...until it didn't.
Usually fires up with a bump of the key. The last time it ran, I bumped the key to the start position and released, but it didn't fire. Tried it a 2nd time and after turning over a couple times it fired up. I backed it out of my garage, shut it off and it hasn't fired since.
When I turn the key to the on position, I see all the normal lights on the dash. No CEL. Glow plug light comes on for a couple seconds like normal and I can hear the lift pump (new this year). When I try to start it, it turns over fine (good battery) but it never hits. Doesn't even act like it wants to start. FWIW, timing belt was replaced 15k miles ago by TDIClub approved mechanic.
I'll check the anti shutter valve when I get home this evening. Also, I'll put another fuel filter on it, just to rule that out although the current filter is recent.
I have a couple more TDI Passats, so I can swap some parts (relays, etc...) to help troubleshoot. Just need a little guidance.
Thank You,
-Jason
nomorotors is offline   Reply With Quote
Old April 3rd, 2018, 17:00   #2
nomorotors
Changed fuel filter. Same problem.
-Jason
Old April 4th, 2018, 09:45   #3
jokila
jokila's Avatar
Fuel Economy: 52/45/40
Here we go:
05 Passat TDI
Thank You,
-Jason
Did you follow the no start thread. If so, tell us what you followed and the outcome. If not, use it.
Ventecomy | Heated seat lighted switch | W8 light |
Blue tint aspherical tinted mirrors | Turn signal convenience | Euro Light Switch | Rear Fog Light | DrawTite Hitch | HIDs | 520 injectors | Engine Cover mod light |
VCDS-HEX/CAN & VagTacho available Houston metro area.
jokila is offline   Reply With Quote
Old April 4th, 2018, 09:56   #4
oilhammer's Avatar
Fuel Economy: fantastic
OBD works... I'd start there.
www.cardocautomotive.com
Old May 21st, 2018, 18:20   #5
nomorotors
I have a full fuel filter. I disconnected the fuel line going into the filter and fuel comes out when I turn the key on.
I checked the acv and its open when the key is on.
I changed the 219 relay near the ecu.
I'm not familiar with vcds, but I plugged it in and there are no codes. I did use it to turn the lift pump on and purge the fuel system.
Still no start.
-Jason
Old May 22nd, 2018, 03:48   #6
oilhammer's Avatar
Look in the data blocks for RPM during cranking. If you have that, then the ECU should have everything it needs to start and run provided it has fuel and the mechanical bits are intact (like the timing belt).
Old May 22nd, 2018, 04:02   #7
1.4TDI PD
Check the crankshaft position sensor and camshaft position sensor if one of them doesn't work properly the car will not start.
1.4TDI PD is offline   Reply With Quote
Old May 22nd, 2018, 06:44   #8
pdtdiarl
TDI(s): golf4
Check also the fuel delivery:
http://pics.tdiclub.com/data/517/PD_...very_check.pdf
pdtdiarl is offline   Reply With Quote
Old May 22nd, 2018, 08:33   #9
nomorotors
Great thanks.
Additional info:
The longer it sits, the harder it is to start. If I drive it daily it starts great. If it sits a day it turns over a few times before starting. If it sits a couple of days I have to cycle the key a few times and it'll start.
New lift pump 1500mi ago.
-Jason
Old May 22nd, 2018, 08:37   #10
oilhammer's Avatar
Sounds to me like you have a loss of fuel prime in that situation, or perhaps the tandem pump is bad.
Old May 22nd, 2018, 09:19   #11
nomorotors
Sounds to me like you have a loss of fuel prime...
That's definitely the way it's acting.
If the tandem pump has failed should I see fuel seepage?
Also, can I bypass the lift pump, do a diesel purge and see if it starts?
-Jason
Old May 22nd, 2018, 10:06   #12
oilhammer's Avatar
I would say loss of fuel prime means air is getting in somewhere, so it stands to reason fuel could be leaking out. However, if it is a tiny leak, and there really is not much pressure on the fuel system, it is possible to not see any leaks. At least, that happens on VE cars. Cannot say I have ever seen it on a PD, and I have never seen a bad lift pump on a BHW (on BEWs and BRMs, yes, lots).
You can remove the thermo-tee on the fuel filter and see if it is full of fuel. If there is a loss of prime inside the head, where the tube feeds the injectors, then you'd see the crankcase oil slowly being fueled up, but it may not be very noticeable at the amounts we may be talking.
Wtb: bhw / b5. 5 passat front crank seal carrier GotEuroCorrado Private TDI Items for Sale/Wanted 12 April 5th, 2016 18:18
2005 B5 long crank to start ChuckV309 VW B5 Passat TDIs 14 September 5th, 2015 18:24
96 passat crank but no start Cleaner13 VW MKIII-A3/B4 TDIs 5 May 30th, 2012 10:35
No Crank 97 Passat TDI, Where to start? snaustin09 VW MKIII-A3/B4 TDIs 6 June 17th, 2009 13:57
Page generated in 0.17074 seconds with 13 queries
[Output: 110.60 Kb. compressed to 93.41 Kb. by saving 17.20 Kb. (15.55%)]
