I was able to get to the ecu (actually put in a cabin filter) into an A3 VR6. No need to remove the wipers. Just a couple of strange "screw clips" that are plastic and you unscrew a tad then pop out, then carefully remove the sealing gasket around the edge. The plastic just wiggled right out. I know that's all that's needed on my B4 as well.
