I buy most of my fuel where it's cheapest. And since I commute for work from Grand Rapids to Hibbing, fuel has generally been cheaper in Hibbing. Either at a local corner Spur station or Murphy/WalMart, sometimes Edwards Oil. It doesn't matter, most of it all comes from the same distribution guys up here. If I buy fuel in Rapids it's at Holiday or Davis Oil on the west end of town, but seldom. Only use some PS additive when it's really cold mostly as peace of mind. I truly seem to get better numbers w/o using any additive(s) in warm weather and have many tanks logged to make that claim, but whatever works, right?
Side note: gas is currently 3.299/gal at home and 40 miles away at work it's 3.049/gal. This has been typical spread for some time now. Diesel doesn't vary near as much, but last weekend on the way up to I Falls diesel was 4.599/ gal most everywhere northwest of Deer River. Wow, the loggers and truckers up that way are getting hosed! Diesel was 3.759 at Murphy when I filled Monday. 690.5 miles/14.117 gal to the rim=48.91 mpg for the tank.
Car doesn't sit out much except at work and if it's below -0F I either start it a couple times during the day or if possible I get it inside the cold warehouse or plug in the FrostHeater for a couple hours before quitting time if there is parking available. Car overnights in the unheated garage at home which helps a lot. Even at -30F, the garage never got less than 15*.
Keeping the speeds down, advanced injection timing with the bigger nozzles and opportune driving make for the only known mpg enhancements. And yes, the older VE type ALH engined cars do better mileage than the newer ones.
It never got above -0F today and the wind was howling (but nothing like out in the plains). Forecast for -25 tonite, again.
