so far i know i takes 5w40 for engine oil change, but i don't know what gear oil, coolant/power steering/brake/clutch fluid and how often should i change them?
GL4 transaxle fluid (G070726A2) - $13x2. 100K miles.
DOT4 brake fluid - every two years regardless of distance.
Hydraulic steering - seems to be stable and doesn't need frequent replacement, if at all.
Engine oil CI4+ 5W40 (or VW505.00) 10000 miles. M1 TDT is one of the better lubricants available at FLAPS.
5000 mile engine oil changes increase wear due to more frequent washing of anti-wear additives with detergents.
