DIESELprogrammer
I installed the Air Lift coil spring air bags this weekend. These are great. I can get up to 3” of lift over the rubber coil spring inserts I was using before (with the same load in vehicle). The ride is softer than with the inserts and the airbags must be acting much as an aftermarket rear swaybar – because the handing has very much improved.
I like to use a split airline system instead of a “T” for airbag and air-shock installations. I had to remove the rear fender liners for the installation and the fuel filler location turned out to be the best spot to locate the air valves. Finally did the Ventectomy while everything was apart.
With approximately 250lbs added to the rear of the Golf – hitch, cargo box and contents, and cooler with other stuff in rear hatch area. The Air Lifts are each filled to 50psi(max). There is a little over 4” from the top of the tire to the fender lip – P205/65 R15 tires about 40% tread left.
I don’t have a picture with the load and stock suspension. Prior to the air bags I had rubber coil spring inserts. If I let all the air out to take a picture, then I have to empty the vehicle (or jack the weight off the springs), air up the bags, and then reload afterward (air up to max, load, then level is the process for use). You can load 250lbs into the rear of your car and compare the difference. I am guessing about 3”.
Air Lift Post 1
Air Lift Post 2
Thanks Dan for the info!
Air Lift Post 1
Air Lift Post 2
