jjcsnlynn
- Joined
- Nov 18, 2007
- Location
- Felton, DE
- TDI
- 02 & 03 Jetta TDI,99 Beetle TDI, 04 Chevy Duramax 2500HD 4x4
This is not a TDI problem, so delete or disregard. I have it on a gasser forum but there is no help there. This forum rocks and you guys are so helpful
2004 Passat 1.8T
So after a timing belt change, VVT valve and chain change I am now getting the 16395. I tried changing the N205 but it didn't fix it.
I don't really understand what this code is telling me, so can someone explain if the intake cam is retarded or advanced...or what it's not doing.
The car runs great. Is there a measuring block that I can monitor and what should the value be?
I had my son, a qualified mechanic, check the VVT chain before I took it off and when I got it back together. I have not tried changing the fuel pump relay yet.
This is my daughter's car and I need to get it working right.
2004 Passat 1.8T
