Blue_Hen_TDI
The directions state that they are copyrighted and cannot be duplicated or shared.Terry mentioned it's quite complicated because of the several coolant routes that are in the system.
Possible to share any directions?
Sent from my One using Tapatalk
The routing is not complicated. Pinch two hose locations on top of the engine and one underneath. Pull off hose and cut off elbow. Connect one Frostheater hose to the hose you cut and the other Frostheater hose to where you pulled off the factory hose. The quarters are maybe a little tighter than in other models, and it really helps to have a cable operated spring clamp tool. You will drip coolant when you remove the factory hose, as it is a vertical fitting that you pull down from. They give you a cap to quickly throw over that fitting, so your leak will be directly proportional to how fast you can throw that cap on.
