Yep check for a blown fuse. I don't know what you drive, so check the cover on the fuse panel. It'll tell you which one is for what. It should be about 20A. A note of caution, do not replace it with a higher amp rating than the one that is in there ! If you keep blowing fuses, look for shorted wires.
