pugman
The wife and I both have 2003 Jetta TDI's and I was wondering if VW (or someone) will come out with a TB that will last 100K miles on the auto trans? My Jetta is a 5/sp and the TB (I am told) is good for 100k while the wife's Jetta w/auto is only good for 80k miles.
I have searched the threads and found that the TDI's with an auto trans has the 11mm IP and the TDI's with 5/sp has a 10mm IP. Why the difference in IPs?
You would think that since both are 2003's and both are TDI's that the TBs should be the same as well and both last until 100k miles.
