Old January 11th, 2015, 11:38   #1
scow1
Default Check engine code P026A Charge air cooler
I have thrown this code a few times already and have not found much info on it for our cars. If anyone has an idea on why it gets tripped or what I need to fix it please let me know.
000618 - Charge Air Cooler
P026A - 000 - Efficiency Below Threshold - MIL ON
This only has happened when when I run my idi cold weather front.
scow1 is offline   Reply With Quote
Old January 11th, 2015, 11:59   #2
YukonLT
Veteran Member - TDIClub Enthusiast
YukonLT's Avatar
Fuel Economy: Good
http://forums.tdiclub.com/showthread.php?t=428159
YukonLT is offline   Reply With Quote
Old January 11th, 2015, 18:10   #3
Lightflyer1
Lightflyer1's Avatar
Happened to me on the Passat with cold weather front on. Removed it and cleared the code and all okay. Only the lower needs to be removed.
2015 Beetle TDI.
Old January 11th, 2015, 18:14   #4
r3trol0gic
r3trol0gic's Avatar
Yep, same here. I only saw this when the temps were above freezing (~35F+) and heavy driving (lot of stop & go, low velocity airflow)
r3trol0gic is offline   Reply With Quote
Old January 11th, 2015, 18:17   #5
Lightflyer1
Mine was highway on cruise at 65 mph. I just don't use the lower any more after reading here some.
2015 Beetle TDI.
Old January 11th, 2015, 18:32   #6
Cogen Man
Cogen Man's Avatar
Fuel Economy: Better than the Toyota FJCruiser
I've had the full IDparts grill block on for about 2 weeks now. Today it was about 35*F with lots of moisture. Driving along for about an hour and the CEL came on solid. Thought she went into limp mode for about 10 seconds. Then ran good. Responsive to the throttle with normal boost and power. As the CEL was not flashing continued to my destination. The DTC was charge air temp high. Before the CEL came on I also noticed my charging voltage was lower than normal. About 13.4VDC showing on my Scangauge. So thought engine compartment heat was lowering my charging voltage along with the charge air temp high and so removed lower grill block. I cleared the CEL and drove the rest of the day without it coming back on. The charging voltage on my SGII was back up to 14.2-14.5VDC with the block off.
The above is what I posted in another thread. If I'd paid attention to what my Scangauge was telling me I would have removed the lower block and never gotten the CEL. With too high an ambient temperature the IC will run too hot and throw a DTC. I now also have an XGauge on my SGII for Intercooler Charge Air Temperature.(ICA*F)
Good that you mentioned the grill block in your post.
Cogen Man is offline   Reply With Quote
Old January 11th, 2015, 20:07   #7
ATR
ATR's Avatar
I've had my lower grill block on since temps have been below 42F. That's been a solid month or so now. I only put the top cover on when temps are below 20F.
I'm thinking that cutting holes in the bottom cover may eliminate the intake temp too high.
I have a question for you guys having this problem... Do you have the tsb intercooler installed or the one straight from the factory?
Drivers Wanted
-2011 Golf TDI 6MT = gone but not forgotten!
-2017 Golf GTI Sport 6MT
***Official maintenance schedule for your VW [PDFs inside]***
ATR is offline   Reply With Quote
Old January 12th, 2015, 08:48   #8
Cogen Man
Cogen Man's Avatar
My intercooler is factory.
Old January 12th, 2015, 16:20   #9
Good Ol' Boy
VeeDubTDI's Avatar
Fuel Economy: see signature
You blocked the intercooler with a cover and now it's throwing codes for the intercooler not performing to specification. Remove the upper cover and you should be okay.
Trusted TDI Mechanics Map || TDIClub Chat
VeeDubTDI is online now   Reply With Quote
Old January 12th, 2015, 16:30   #10
MichVW
I had the same thing happen over the last few days.. Didn't notice this thread. Posted one of my own a few above this. I am pulling the uppers off of both my vehicles. ID parts should sell the separately. I will probably not put the uppers back on. Funny thing is that mine only started throwing CELs when temps got down into the teens. Have been running uppers and lowers since before Christmas even in 40 degree temps with no issues. So much for my $200.00 investment! (2 sets).
MichVW is offline   Reply With Quote
Old January 12th, 2015, 19:49   #11
Samcar222
Fuel Economy: 35-38 MPG town, 45-48 hw; {40 town, 51.6 hw w/ massive tailwind, 42.6/tank are records}
Generally the uppers should only be used below 25*f (my experience). My lower is on when it's below 40*f. I haven't had codes or issues, and I do have a TSB kit on my car. This is a really puzzling phenomenon... any chance the people who are getting codes are drawing intake air directly from the engine bay (i.e. bypassing the intake snorkel) Check that your intake snorkel isn't removed, as the dealer removed it as a 'bandaid' if your car presented IC condensation/icing issues. It attempts to increase intake air temps by drawing warm engine bay air in, instead of colder air from the intake slits right at the tip of the hood.
Just a random thought that popped through my head.
'10 JSW TDI-Moms-Salsa Red-DSG-rear side airbags-pano roof-mats/splash-88k problem free miles. 5 oz of stanadyne perf./fillup!
'03 ALH Jetta Wagon 5mt 280k lots o' rust
'01 BMW 530iA-Dads-Anthracite-118k
Samcar222 is offline   Reply With Quote
1JO 121 467A air guide for charge air cooler jaredaggie TDI 101 2 November 27th, 2011 06:55
Oil in the charge air cooler pipes and hoses. bthober VW MKV-A5 Golf/Jettas 9 October 7th, 2011 12:11
Oil leak from charge air cooler? corpsman VW MKV-A5 Golf/Jettas 7 April 7th, 2011 04:12
charge air cooler sensor plug ed1380 VW MKIV-A4 TDIs (VE and PD) 3 January 2nd, 2010 13:29
Charge air cooler connecting tube (pix) natureboy68 VW MKIV-A4 TDIs (VE and PD) 2 October 20th, 2006 21:36
Page generated in 0.17368 seconds with 11 queries
[Output: 108.47 Kb. compressed to 91.64 Kb. by saving 16.83 Kb. (15.52%)]
