To DIe for
Howdy all,
My passenger side inner CV boot is torn and has been for quite some time. Being lazy (and cheap) I never did anything about it. The torn boots been slinging grease all over the heat shield, so I would imagine any grease thats left (if any) on the joint has spread pretty thin. Recently I started feeling some pretty decent vibration during acceleration (no noise yet).
Im looking to take care of this with the least possible downtime and of course cost. Also, I dont have the proper tools to do the job myself, so I'm thinking I buy the parts (OEM only) and pay my local front end guys to install.
Is it safe to say that the original joint is shot with said vibrations? I can get an OEM replacement joint w/ boot kit for about $100 bucks and whatever the labor costs. Problem is, my mechanic friend (non TDI) says that I should replace the entire axle because the outer joint would also be worn, and the shaft could possibly be bent. Raxles sells an OEM axle shipped for $250.
Wouldn't it be cheaper to install the only axle as opposed to the CV joint? Pay more for parts and less for installation?
