Most air filters are not anywhere near dirty by 40K miles though.Joester said:i thought it was 20k for both, but i guess thats a good thing, lol
What brand filter?Thor said:Lucky you can get 20k, mine lasted about 17k and starts leaking out the water drain on filter, so i change it every 10k with oil
Did it *look* dirty, or was it actually dirty? There is a difference.egibbys said:I checked my air filter, even though I know you aren't supposed to break that seal, but my air filter was super dirty. It only had 20k on it but after seeing it I'm glad I checked and swapped it out.
Well I dropped it on the ground and a ton of dirt and lint fell out of there. Like a thick layer. Cabin air filter was also the same way. It was also the same age as the engine filter.Bob_Fout said:Did it *look* dirty, or was it actually dirty? There is a difference.
I replace my CAT fuel filter at 40,000 miles. Its easy to remember to change the fuel and air filters at the same time.SheeB said:Wow, save yourself some money and invest in a CAT filter system. The CAT filters filter better and are cheaper and require a much longer change interval. There is also the newer Nicktane setup, which I like the head design better as I have scratch marks on my CAT filter head as it was a PITA to seperate from the filter the last change.
i buy them through vw, oemBob_Fout said:What brand filter?
