Old April 21st, 2009, 06:11   #16
hughgb
TDI(s): jetta
Default radio wiring
Does anyone know the colour code to determine what wire goes where, ie: red -power, Grenn - ground, Etc. I have a 99 Jetta TDI diesel. Thanks.
hughgb is offline   Reply With Quote
Old April 21st, 2009, 12:42   #17
Matthew_S
Matthew_S's Avatar
Fuel Economy: 41-46
This link gives a really good description of what the different colors mean.
http://lennysvw.com/WIRINGid.htm
Matthew_S is offline   Reply With Quote
Old April 21st, 2009, 13:14   #18
Sip'n Diesel
Veteran Newbie
Sip'n Diesel's Avatar
Fuel Economy: 900 miles on 16.9 gallons - Personal Endurance Record
Thumbs up
whitedog you will likely be receiving a Nobel Peace Prize within a couple of years... I am not good with this (electronics/wiring) type of thing at all. I bought one of those cheap-o multimeter/voltmeters awhile back and I still haven't learned how to use it properly and how to avoid frying things and especially avoiding self-electrocution
this thread gives me motivation to start learning, because it's only a matter of time until the electrical gremlins decide to pay me a visit. your idea is a very good one, because it does take a lot of searching/flipping to find something specific (especially if you are me)
OTOH I have become pretty good with a MityVac, which I purchased with the multimeter
2003 Jetta GL - 5 Speed Manual - Alaska Green - Dieselgeek Panzer Plate & Full Metal Jacket - DGRP - ScanGaugeII - WeatherTech Deflectors - Vent Delete - DRL Delete - Muffler Delete - KONI STR.T - Redneck Armrest - 5 Brake Lights - Otherwise all stock, for now
Sip'n Diesel is offline   Reply With Quote
Old April 21st, 2009, 15:35   #19
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
I personally prefer the "E-plan" type schematics as the Bentley manual reproduces to the 'overview' type being considered here.
The E-plan is basically a 'ladder' diagram laid over on it's side. Positive or + voltage is on top and progresses down from "hot" to switched to LRR through consumers and finally down the page to ground or - voltage at the bottom.
My 1969 Sonett has the overview format, and even with it's simple enough wiring it is barely comprehensible to me.
Svante Arrhenius 1896
Old April 21st, 2009, 16:30   #20
whitedog
Cool. So if I get stuck understanding something, expect a note.
Old April 21st, 2009, 19:16   #21
Ookpic
Ookpic's Avatar
Fuel Economy: Average 41
Had a little time tonight to work on this. All symbols are now imported and here is a draft. It is clickable to get larger version.
LMK what you think.
2002 Jetta TDI (Reflex Silver) 5 spd | GLI Leather Interior | Malone Tuning Stage 5 | 17/22 Hybrid turbo | Eurojet SMIC | PD150 Intake | PD150 TIP | PD150 Upper Airbox | R32 Lower airbox | R32 DSG Snorkel | ARP Headstuds | WaveTrac LSD | DBW Tuned R520 nozzles | DC Stage III+ Clutch | PD150 Stealth Race Pipe | Whitbread Performance Innovations custom 3" exhaust & IC piping | TT LCA Bushings | Durometer 80 Dogbone with poly insert
Ookpic is offline   Reply With Quote
Old April 21st, 2009, 20:15   #22
whitedog
That looks great.
The only thing that I see from a quality viewpoint is the wire connection numbers in the CCM should be right at the point where the wire comes in rather than in the corners.
I like having the fuse number and amperage right at the fuse. On the one that I am working on now, I have them just as a reference number but I'll change that.
Also, I will be going to putting the ground points right at the device rather than running them all to the bottom. I will also have the location of each of those ground points.
And I need to show the ground for the CCM.
I'll go over it one more time and show where I could have done better in my drawing and I think that it would be GTG.
Old April 26th, 2009, 11:00   #23
whitedog
Here is another version for the >2000 JGB. We still need some feedback on some things.
HERE is a PDF of the reference numbers. this will show you where ground #42 is and what device "B" is and where to find connection A32, etc.
After working on another diagram, it's obvious that Matthew was right about putting the grounds right at the devices rather than running them down to the bottom as a common ground so thanks for that.
The question up for discussion is how to handle different engines/transmissions/years/models. In this example, I have the automatic and manual transmission on the same page. Would it be better to have separate pages for each one, or the same page with all applicable scenarios (e/t/y/m) pointing to the same page?
I would appreciate the feedback, especially the bad and the ugly. The good feedback mostly feeds the ego and I'll skip that, but thanks.
Old April 27th, 2009, 04:36   #24
Lug_Nut
Lug_Nut's Avatar
...and expect a reply in return.
Old April 27th, 2009, 04:46   #25
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Why on Earth are you trying to reinvent the wheel? VAG's factory diagrams are simple and easy to use. I just wish there were not so many mistakes in them, but as far as layout the track-style (or 'ladder' type as Lug Nut calls them) is pretty good.
VAG went to these WAY back in the early '70s due to increasing complexity, so you are attempting to go backwards????
oilhammer
www.cardocautomotive.com
Old April 27th, 2009, 06:12   #26
whitedog
It took at least 9 pages to find all of the components and wires for the A/C system on the 98 Beetle. That is not easy to follow. I have it all on one drawing.
Old April 27th, 2009, 06:27   #27
oilhammer
oilhammer's Avatar
But I prefer (and most professionals prefer) to see ALL the wiring, since typically when you are looking at a diagram it is to find a problem. And so often electrical problems manifest themselves in ways that tie seemingly unrelated circuits to one another.
For instance, did you know that on a 2002 Jetta wagon if you remove one fuse, not only will the A/C not work, but the parking brake warning indicator won't work and the headlight DRL circuit won't work. If you just were looking at the A/C wiring, and not the rest of the stuff, you would NEVER be able to figure out how those 2 systems are related.
Troubleshooting electrical problems without all the info would be like troubleshooting a brake noise without driving the car.
I think your project would be helpful to some folks for the purpose of training or understanding the theory behind automotive electronics, but there are already plenty of textbooks for such pursuits.
But for actual troubleshooting, no way. I think your efforts would be better spent illustrating how to actually use the diagrams, which I for one find pretty easy and straightforward. But I have to, my career depends on it.
oilhammer
Old April 27th, 2009, 07:55   #28
CoolAirVw
CoolAirVw's Avatar
TDI(s): Jetta
Fuel Economy: 40
I think having a database of schematics on your website would generate lots of traffic and be excellent for business.
I think it would be a good business move.
With regards to "what else is on the circuit" a simple dead end branch on a circuit that ends with ".... to a/c clutch" or "...to park brake indicator" or "... to headlight DRL" would be sufficient, and of course on the a/c clutch scehmatic it would need a dead end branch that said.. "...to park brake indicator".
Richard. ASE Certified Master Auto-Technician with L1 Advanced Engine Diagnostic Rating. ATRA Certified in Rebuilding, Diagnosing & Installing Transmissions.
LOOK AT MY YOUTUBE CHANNEL -->
https://www.youtube.com/user/CoolAirVw/
Now offering Malone Tunes!..............http://www.kansascitytdi.com/
CoolAirVw is offline   Reply With Quote
Old April 27th, 2009, 08:36   #29
DanG144
Originally Posted by oilhammer
For instance, did you know that on a 2002 Jetta wagon if you remove one fuse, not only will the A/C not work, but the parking brake warning indicator won't work and the headlight DRL circuit won't work. If you just were looking at the A/C wiring, and not the rest of the stuff, you would NEVER be able to figure out how those 2 systems are related...
Brian, which fuse would that be? (I will have to wait until later to look at the schematic.)
Dan
Old April 27th, 2009, 08:38   #30
oilhammer
oilhammer's Avatar
I believe it was the 7.5A #5 fuse in the interior fuse block, IIRC.
oilhammer
Page generated in 0.16956 seconds with 10 queries
[Output: 129.36 Kb. compressed to 107.33 Kb. by saving 22.03 Kb. (17.03%)]
