andytdiland
I am having trouble with injector adaptation after I swapped an engine on a 2012 passat tdi cr.
The engine ran perfect on the parts car. I put this engine on my car and I cannot get it to run. I checked the fuel and all pumps run good, I cracked the fuel lines at the injectors and there is plenty of fuel there.
I did the injector adaptation based on the Ross-Tech procedure and everything looks good on with VAG-COM, but no start. I took the glow plugs out and there is no fuel coming out of the injectors. It seems like the ECU does not fire the injectors.
Is there anything else (ECU adaptation wise) that has to be done when swapping the injectors/engine from another car on a CKRA engine?
