richmondvatdi
- Joined
- Feb 5, 2005
- Location
- Chesterfield, Virginia
- TDI
- 2005 Passat Wagon 5-speed,2003 Jetta GL Wagon, 2003 Jetta GLS Wagon, 2013 CC 2.0T
Long story short: While changing front struts, I removed two brake lines (from master cylinder to ABS module) in order to access one of the strut mount nuts. I finished installing the struts and then put the brake lines back on. Of course I need to bleed the ABS pump. Hooked up VCDS but it won't see the ABS module. It also cannot see the Transmission Control Module and some other stuff. (I will post a scan next but want to get this in front of some eyes quickly.)
In poking around the engine compartment I noticed a thin red wire coming off the + battery terminal that looks like it was broken. I had also pulled the battery out during some of the work I've been doing on the car not related to the struts, and I'm thinking maybe I accidentally broke a connection to something important. Here is a link to a picture of the mystery wire in question circled in yellow: https://goo.gl/YJEcDy
I cannot find where it might have been connected. Unfortunately I don't have the Bentley or any wiring diagrams so I am hoping someone can help. Where does that wire go and could it be causing my problem?
(There is also a connector that seems to be a dead-end (circled in black). Thinking that may be related to the 5-speed swap the PO did.)
