First gear grind: clutch or synchro?
9mmkungfu
Virginia
2010 Jetta SportWagen, 2006 Jetta
Hi all,
New here and just recently picked up a 2000 TDI w/ 5-speed. It's got 205k on the original clutch.
If I depress the clutch, wait one second, and shift into first gear, it works fine.
If I depress the clutch and quickly shift into first gear, it grinds.
Is this a synchro going bad or a clutch issue or.. fluid?
Thanks in advance!
Yblocker
Oakland, CA
1997 Passat
With the car warmed up, try the following drill while shifting in to reverse. Depress the clutch and gently (but immediately) engage reverse. You'll be able to feel the reverse idler gear spinning and grinding if the clutch is dragging. A little clunk under those conditions is kinda normal, but the "Grind a pound for me!" comment from your neighbor isn't.
The first gear synchro doesn't get a lot of wear. It's 2nd and 3rd that take the most abuse from powering through the gears :p
If you think the clutch is dragging, you might also detect a low to the floor engagement point at the pedal, possibly indicating air in the system in which case bleeding may help. It could be a failing slave cylinder, or worse case- a release lever that is starting to bend that will require trans removal to repair. I think you have the dual mass flywheel in that car, which is also prone to failure.
9mmkungfu
Virginia
Thanks for the reply! I'll run that test later today.
I was already looking at 02M conversions :)
Ski in NC
Wilmington, NC USA
2001 Jetta ALH 5sp stock
If it does not grind by delaying shift into first after pushing the clutch, it does not sound like a clutch issue. Second that about seeing if reverse grinds, as it has no synchro. Push clutch, count to three, go in reverse. If no grind, clutch is ok.
Also try the same with clutch pedal 1/2" above the floor. Should still not grind.
Change your tranny oil. I used the dealer spec'd and supplied stuff (g60 IIRC) and my shifting went from ok but notchy to smooooth as butter.
9mmkungfu
Virginia
Reverse seems to work ok. I forgot to try it with the clutch pedal above the floor.
Without having to wade through a search, is the factory gear oil the best stuff to use?
9mmkungfu
Virginia
Alright. I'll test out the reverse engagement with the clutch pedal 1/2" from the floor later today. If it checks out okay, what do you all think the problem is going to be?
I can live with a one second delay shifting into first. But I would like to know what's causing it.
Yblocker
Oakland, CA
1997 Passat
If reverse engages without grinding, then the clutch is releasing, the input shaft is coming to a stop, and first gear shouldn't grind either.
The hydraulic system is ideally supposed to be flushed every 2 years or so. If it were me, I would perform that bit of maintenance, which would bleed any air too. Do a search here to learn about it.
I'd also change out the trans oil with the G60 from VW, and I'd be inspecting the shift linkage.
tat2
New Orleans
1999.5 jetta tdi black. 2014 jetta tdi black
I will revive this thread instead of making new one.
So I been having all kinds of shifting problems. Hard shifting, grinding into first from dead stop. Randomly grinding into other gears when driving. As the car got hotter it got worst. It would also leerch forward with clutch pedal all the way down. I changed the trans fluid it made shifting a little better but everything was still there.
So I decided to try changing the slave cylinder ($100 from oreillys) it was fairly easy about an hour. Remove two bolts remove the line, bench bleed the new one, out the line and clip in install the new one. Hit it with a vacuum bleeder for three cycles and done.
While I was at it I sprayed the shifting linkage with some white lithium lube.
I just say it was worth the effort!!! Car shifts beautifully! It has brought the fun back. I would sometime dread the bad shifting days. Now it is like I got a new machine and I can finally enjoy all the performance mods!!!!
tat2
New Orleans
blacksi
Dayton
Jetta
Man, Thank you so much...After my tranny went out at 450k miles I put a junk yard pull in with only 130K at that time I also used that slave since it was newer. It has had a slight grind for 40K miles and finally started to get worse. I was about to yank the tranny tonight but saw this and stuck my old slave back in and waaa laaaa no more ginding! I also used the 130k clutch and always thought I missed something and they weren't exactly the same...
