turbobrick240
- Joined
- Nov 18, 2014
- Location
- maine
- TDI
- 2011 vw golf tdi(gone to greener pastures), 2001 ford f250 powerstroke
A. Check the expansion tank for signs of corrosion related debris/sediment.And how to propose I test that if the color goes nearly flat ? Other than replace/flush often ?.
B. Use an inexpensive multimeter to test the conductivity of the coolant.
C. Use an inexpensive hygrometer/coolant tester
D. Have a garage do any/all of the above if you are not capable.
