nord
- Joined
- Mar 5, 2010
- Location
- Southern Tier NY
- TDI
- All turned back to VW. Now a 2017 Hundai Tuscon. Not a single squalk in 10k miles.
My silver SE... Four months and just shy of 10k miles. Not a single problem! So time for the 10k service and a decision. To the dealer for a "free" service at the waste of a day or do it myself?
We own a heated shop equipped with a lift and the necessary tools so there isn't a worry about laying under a wet dripping car on a cold concrete floor. A huge advantage I'll admit. Then the comments here and elsewhere about oil jockeys at dealerships... The spills, the overfills, and often a question as to whether the correct oil is being used. You may assume that the dealer idea got canned.
So... Up on the lift with belly pan removed. Imagine! An insulated oil pan. A very nice touch. The belly pan? Also very nice, but I can understand why this isn't a car to take to Jiffy Lube. The rest of the underside of this car is well executed too. Just not a vehicle built to accommodate a high volume low cost shop.
Then the filter. I've heard that it's next to impossible to survive a filter change without oiling that nice piece of white insulation. I'm here to tell you that it's not impossible, just next to impossible. For want of a slightly longer piece of steel tubing and because VW saw fit to route a cable harness so tightly in the filter area, the process of filter removal is difficult to say the least. Time-consuming and very tight. I can at least understand why a tech might be tempted to take some shortcuts.
For the added few minutes I removed the plastic cable clamp for the wire harness, along with the small hose clamp toward the front. The insulated steel piping was covered with a simple plastic bag, then the cap and filter were cleanly removed. There is just enough room to get the job done without making a mess if one takes some time and is careful. VW could have made this process easier!
All in all I'm impressed. I remain of the opinion, though, that VW owners must either have a bit of talent and the proper tools or plan on shelling out large chunks of change for what would seem minor repairs and maintenance. The oil and filter change alone is a case in point if one wants to have the job done correctly.
Even if we lay aside the $50.00 cost of oil and filter, a proper change of this type is not a ten minute job. It's more of an hour to do things properly, though I'll admit to being slightly anal. Done the way I want my car serviced I'd guess nearly $100 of labor plus oil and filter. Ouch!
So up on the lift to remove the pan and drain the oil. Once drained and the plug replaced, then down for the filter removal. Once the filter has been removed and replaced and a new charge of oil, then startup and inspection. Assuming all is will, then back up in the air for lower end inspection and pan replacement.
Yup! There's the down and dirty method too. It's quicker and cheaper if all goes fairly well. And much more expensive if things don't go well. I'll pay my $50.00, take whatever time a proper job requires and remain a very pleased Passat owner.
