Hi fellow TDI drivers,
Last week i replaced my engine wiring loom because of a hungry cooling fan that eat my loom... but after this replacement the car wound start.
i have checked the j49 relay and send of my ecu to be-sure it was not burned out or other issues because of electric wiring.
If i try to start the car the dash gives a Waring "engine failed workshop"
i'm working on a 2011 Golf 6 GTD (CFGB)
5196 - Relay for Fuel Pump 2 (J49)
P2632 00 [167] - Open Circuit
MIL ON - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 163163 km
Date: 2000.00.00
Time: 00:00:00
If swaped the relay with one that was already in the car and works
Does some one does have a suggetion where to look for ?
VAGCOM scan:
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: WVWZZZ1KZBWXXXXXXXXXXXXXXX
Chassis Type: 1K (7N0)
Scan: 01 03 08 09 10 15 16 17 19 20 25 37 42 44 46 47 52 55 56 62
69 72 77
VIN: WVWZZZ1KZBW217358
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
20-High Beam Assist. -- Status: OK 0000
37-Navigation -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
69-Trailer -- Status: OK 0000
Address 01: Engine (J623-CFGB) Labels: 03L-906-018-CFF.clb
Part No SW: 03L 906 018 BB HW: 03L 907 309 R
Component: R4 2,0L EDC H23 7818
Revision: 42H23--- Serial number: 00000000000000
Coding: 00190012043400080000
Shop #: WSC 01357 011 00200
ASAM Dataset: EV_ECM20TDI01103L906018BB 003005
ROD: EV_ECM20TDI01103L906018BB.rod
VCID: 6BD5212782702B46511-803E
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 163163 km
Date: 2000.00.00
Time: 00:00:00
4967 - Fuel Temp. Sensor A (G81)
P0183 00 [172] - Open or Short to Plus
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Mileage: 163163 km
Date: 2000.00.00
Time: 00:00:00
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Coding: 143B600D09230001280E06E990210042310800
VCID: 76E30053C132E6AEBEF-8023
No fault code found.
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 5K0 907 044 EA HW: 5K0 907 044 EA
Component: Climatronic H17 1010
Revision: 00003001
Coding: 0000000002
ASAM Dataset: EV_Climatronic A01010
ROD: EV_ClimaAutoBasis_SE36.rod
VCID: 6ED32833B162DE6E76F-803B
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 087 J HW: 1K0 937 087 J
Component: BCM PQ35 H 103 0615
Revision: 00103 AD
Coding: 40180A3A88251AC040880088740009E443550088736D8560E48000240040
VCID: 387FCE6B8BA650DE6C3-806D
Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 19011 26 0512
Coding: 009795
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 260111 05 54 0403
Coding: 0330AD
Address 10: Park/Steer Assist (J791) Labels: 1T0-919-475.clb
Part No SW: 1T0 919 475 P HW: 3T0 919 475 C
Component: PARKHILFE PLA H08 0116
Revision: -------- Serial number: 13961327401136
Coding: 11000A
Shop #: WSC 12345 123 12345
VCID: 489FBEABFB46205E1C3-801D
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5C0 959 655 B HW: 5C0 959 655 B
Component: AirbagVW10 013 0613
Serial number: 003G5RA0BM19
Coding: 00003947
ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
ROD: EV_AirbaVW10SMEVW360_VW01.rod
VCID: 3169F34F60DC81962BD-8064
Crash sensor for side airbag; driver side:
Subsystem 1 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME306E735AZZZ+
Crash sensor for side airbag; passenger side:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME0713745AZZZV
Crash sensor for side airbag; rear driver side:
Component: S.Sens.Fahr.H --- ----
Serial number: 3512QSME3A037425ZZZP
Crash sensor for side airbag; rear passenger side:
Component: S.Sens.Beif.H --- ----
Serial number: 3522QSME08047E7EZZZ3
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 507 AJ HW: 5K0 953 549 B
Component: Lenks.Modul 008 0090
Revision: -------- Serial number: WHRPIxhxHHHrU
Coding: 108A144000
ASAM Dataset: EV_SMLSNGKUDS A05001
ROD: EV_SMLSNGKUDS.rod
VCID: 78FF0E6BC32690DEAC3-802D
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H07 0013
Serial number: 0197306
Coding: 820000
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 5K6 920 881 A HW: 5K6 920 881 A
Component: KOMBI H04 0206
Coding: 170F00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
VCID: 3365F9479AC0B386591-8066
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 C HW: 1K0 907 951
Component: J533 Gateway H37 0614
Revision: H37 Serial number: 280111F2000240
Coding: 350002
VCID: 306FF64B63D6889E243-8065
Address 20: High Beam Assist. (J844) Labels: 8K0-857-511.clb
Part No SW: 5K0 857 511 B HW: 8P0 857 511 C
Component: FLA H04 0006
Revision: AA001002
Coding: 02018B6B74745D545420363E00
VCID: 2D51EF3F74E4E5760F5-8078
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H04 0206
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
ROD: EV_Immo_UDS_VDD_RM09_VN35.rod
VCID: EADBA4230D8AB24EAA7-80BF
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 D HW: 1T0 035 680 C
Component: RNS-MID H50 4120
Revision: AB001001 Serial number: VWZ6Z7L2017029
Coding: 04070002010000900000
VCID: 2F6DF5377EE897663D9-807A
Subsystem 1 - Part No: 1T0 919 859 B
Component: EU West V12 8195
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 5K0 959 701 D HW: 5K0 959 701 D
Component: Tuer-SG 009 2151
Coding: 0000182
VCID: 3365F94752C0B386591-8066
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 70 3201
Revision: 00H20000
VCID: 3467FA5B57CEB4BE40B-8061
1 Fault Found:
03803 - Steering Angle Sensor for Steering Aid
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
Battery Volts: 12.5 V
PD
Temperature: 20.0?C
Count: 2
Steering Angle: 0.00?
Count: 0
SteerAng n.Init
Address 47: Sound System
Cannot be reached
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 5K0 959 702 C HW: 5K0 959 702 C
Component: Tuer-SG 009 2119
Coding: 0000438
Address 55: Xenon Range Labels: 5M0-907-357-V2.lbl
Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
Component: AFS-Steuergeraet 0148
Revision: 00H04000 Serial number:
Coding: 1442908
Subsystem 1 - Part No: 7L6 941 329 B
Component: AFS-Lst.-Modul l 0005
Coding: 00000022
Subsystem 2 - Part No: 7L6 941 329 B
Component: AFS-Lst.-Modul r 0005
Coding: 00000022
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 5K0 959 703 D HW: 5K0 959 703 D
Component: Tuer-SG 007 2101
Coding: 0000144
Shop #: WSC 01357 011 1012552
VCID: 3561C75F5CB4ADB6775-8060
Address 69: Trailer (J345) Labels: 1K0-907-383-MY8.lbl
Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
Component: Anhaenger H09 0100
Revision: 3A001001 Serial number: 00008030208245
Coding: 0100000100000000
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 5K0 959 704 D HW: 5K0 959 704 D
Coding: 0000144
VCID: 3663C05341B2A6AE7EF-8063
Address 77: Telephone (J412) Labels: 3C8-035-730-A.clb
Part No SW: 5N0 035 730 D HW: 5N0 035 730 D
Component: Telefon 009 0511
Revision: -------- Serial number: 35909603103975
Coding: 020100000100000000010000
ASAM Dataset: EV_UHVPremi A01005
ROD: EV_UHVPremi_SE36.rod
VCID: 29591B2F480CF956E3D-807C
End ---------------------------------------------------------------------
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 163163 km
Date: 2000.00.00
Time: 00:00:00
VAGCOM scan:
69 72 77
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 163163 km
Date: 2000.00.00
Time: 00:00:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Mileage: 163163 km
Date: 2000.00.00
Time: 00:00:00
Revision: 00H31001
Revision: 00003001
Coding: 0000000002
Revision: 00103 AD
Coding: 009795
Coding: 0330AD
Coding: 11000A
Coding: 00003947
Coding: 108A144000
Coding: 820000
Coding: 170F00
Coding: 350002
Revision: AA001002
Coding: 000000
Coding: 0000182
Revision: 00H20000
1 Fault Found:
000 - - - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
PD
Temperature: 20.0?C
Count: 2
Count: 0
SteerAng n.Init
Cannot be reached
Coding: 0000438
Coding: 1442908
Coding: 00000022
Coding: 00000022
Coding: 0000144
Coding: 0000144
