jimbote
Certified Volkswagen Nut
Just wondering if anyone has considered this option?.... quicktime (lakewood) RM-4082 bell housing for mating audi/vw 4,5 cylinder and VR engines to a tko/muncie etc trans, coupled with, a novak GMAX15 for mating the chevy bell housing with the four bolt rear pattern (tko, muncie etc.) to the AX15/R150/AR5 etc ...the lakewood measures 6.3" depth and the novak appears to be about an inch thick so that would put it into the range of a stock taco V6 R150 input length/bell housing depth ....you would have to use an internal slave, AUDI/VW longitudinal flywheel, pressure plate and starter along with an 8 7/8" toy disc but it would be a pretty sweet setup....by the time you put it all together you would prob be in for around $1500+ ...the biggest reason I'm even contemplating this is that I just pulled the trans in my taco to replace the pressure plate with a heavy duty ACT unit and I discovered my "newly" machined pilot was trashed due to the trans being misaligned to the crank center....soooo, I ordered a new ACME plate to replace my current "clone" thinking it would line up tighter than my current plate, tested it and it has about 2-3 mm of slop on the studs, no better than my copycat plate! (.010 or less eccentric allowed on most applications)...this misalignment can lead to worn pilot bearings, input bearings, clutch vibration etc (as i experienced).....I can rectify this by finding center with a dial indicator and drilling for dowels but just looking for a fool proof solution that doesn't require cutting up a transmission case and bell housing in order to make a centering jig....BTW it appears both the lakewood and the novak use factory dowel pins to locate rotational center on their adapters
