I believe I used that exact word to describe his and my buddy Daniels work "brilliant"Brilliant and beautiful! Thanks for sharing Inspirational for the next iteration.
82' vanagons unite!! ...my twinpass intercooler is on the way!!Thanks for posting this. My next setup will be similar to this.
the front of the intercooler is almost right against the floor with 2.5-3" of tilt down at the rear .... hope that answers your question..Question: How much space is above the intercooler core? (i.e. trying to understand the the route the airflow takes when exiting)
Thanks,
Mark
that's still really good for an a2w setup.... i literally wrangled for months over whether or not to go a2w ... i even wasted $500+ in a water meth injection system .... when my buddy came up with this i was sold ....Agreed. If I was to do it all again (I don't want to), I would do this.
My current setup with two sequential A2W intercoolers and a 24x12 radiator mounted underneath yields IAT at 10-35*F above ambient. The worst I have seen is 140*F on a 100* degree day on a long up hill. Yesterday I was driving on a cooler day and IATs around 100 on a long freeway run. Around town 80-90*F are the norm.
The A2A setup above is superior, I think because the IATs are still lower than mine and more importantly, the complexity and weight are much lower.
i'll need to measure it when i get back fom the west coast but i would say you're correct, a bit longer tubing than a normal fmic but not crazy longSimple and effective... can't argue with that. How much piping would you say is there? Probably a touch longer than a typical FMIC install but not by much.
I don't have the van or pictures anymore. The van is still running around arizona/southern California last I heard. My "new" van has a similar, more compact, intercooler arrangement but it's not as effective as the amosdoodle setup. New setup has intercooler right under the 50 degree wedge just below the turbo....back from the dead...
I've referenced this multiple times over the years.
Thanks for your contribution!
Could you please fix the broken picture links?
I'm also curious how this setup has been working.
