Humpty
Hi ive been hearing good things about it but i noticed it is not GL-4 compliant. It does say its GL-3.. im just wondering if it is safe to run in my 02 jetta
One qt "bottle"?Pennzoil from Autozone, here. One bottle filled it on my ALH.
Yep, one quart. Actually slightly under one quart and it was overflowing.One qt "bottle"?
I've always found it required almost two full qts for a refill.
use regular synchromesh, the friction modified is for gearboxes with clutch type limited slip diffs ...our trannies do not have clutch type limited slip diffsThey use in 600 hp Vett
There is two types, of it????
I don't mean brands.
If so which is the better of the two if true??
My 02j required just under TWO Liters. I have the last 1/5 of a bottle still left.Yep, one quart. Actually slightly under one quart and it was overflowing.
I was expecting ~1.5 and had two on hand, but the second is riding in my trunk.
I'm attributing it to trapped fluids somewhere inside the transmission and planning to drain and fill it again some time soon, just for peace of mind.
I used pennziol to fix my NB trans getting stuck in 5th. If I didnt take it out of 5th before stopping it was really hard to get it out, this was at about 250k with the factory fill.Which Synchromesh are you guys using? AC Delco or Pennzoil? I want to see if this will fix my transmission's unwillingness to downshift from 5th to 4th without double clutching. And if I find the right one we may also stock it.
What is it with you and Amsoil?Amsoil has a synchromesh trans lube.
Has anyone tried it?
GM is semi syn., and the Amsoil is 100% syn..
Is the synchromesh safe for a 6 speed man., trans., in a 2010 Jetta TDI?
I used "Amsoil MTF" in my 06 accord's manual transmission. Made a huge difference in shifting quality. When cold it vastly improved how easy it was to shift. When warmed up it was smooth as butterAmsoil has a synchromesh trans lube.
