$600BeaterTdo
Hello all, new to the forums here! I bought a 600 dollar tdi with a going 01m in it (surprise) so I bought a 5 speed, I’m all set for the 02j swap! Only question is, has anyone swapped the 02j and left the cruise out of the equation? Along with not re coding? I’m not to worried about making it perfect, I never use cruise (and that seem like the most confusing part of the swap) and I’m not worried about check engine lights. I don’t have a laptop for the vag com software, nor do I want to spend money on the mobile app. (600 dollar car here!). If not re coding is gunna screw up the drivability of the car then I’ll do it, but like I said, I’m not worried about having check engine lights. I know, “ I should just do it right” but I’m trying to pull this off over the weekend cause I need the car for work Monday, just trying to make this as simple as possible. (Later down the road I’ll get to re coding, but for now I just need to know if it’ll be drivable without doing so) Any help would be greatly appreciated! Btw it’s a 2000 gls Jetta tdi, transmission for a 99 tdi Jetta!
